Feature Layer Search and Create Feature Layer from Selected Features
3167
03-11-2015 09:46 AM
BradGagliano
I am rather new to arcpy, however I am moving my AddIns from VB.net over to python.  I am trying to search for a feature layer(s) and if found check to see if they have a selection.  If so create a feature layer from that selection. If not do nothing.
I have attached a portion of the code I'm trying to use.
Thanks in advance.
Brad
BlakeTerhune
MVP Regular Contributor
Assuming this is the snippet of code you're asking about?
for lyr in arcpy.mapping.ListLayers(mxd, "CRASHES1999", df):
    if lyr == "CRASHES1999":
        desc = arcpy.Describe("CRASHES1999")
        in_table = "CRASHES1999"
        field_names = "YEAR"
        if desc.FIDSet:
            with arcpy.da.SearchCursor(in_table, field_names) as cursor:
                for row in cursor:
                    arcpy.MakeFeatureLayer_management(in_table, "SelectedCrashes1999")
        else:
            print "No Features Selected for CRASHES1999"
        del desc
        del in_table
        del field_names
Did you have a specific question or problem? Just guessing, but I see you're passing the field names for the search cursor as a string. According to the documentation, it needs to be a list or tuple. Try this instead:
field_names = ["YEAR"]
BradGagliano
It seems I have answered my own question.
I had
if lyr == "CRASHES1997":
I should have had
if lyr.name == "CRASHES1997":
BlakeTerhune
        if desc.FIDSet:
                for row in cursor:
        else:
        del desc
        del in_table
        del field_names
BradGagliano
Thanks, this did seem to make it run smoother and quicker.
