Getting a spatial reference from a script tool parameter
11231
13
03-10-2015 07:00 AM
NeilAyres
Been stuck on this for a while this afternoon.
I have been writing a script tool which loads some data from a table in a db.
I needed to then set the spatial reference of the coordinates.
So, in my script I had :
SR = arcpy.GetParameterAsText(1)
And in the tool properties, this is set to a Coordinate System data type. So you get the nice pull down list of the available coordinate systems.
However, this returns a text representation of the prj, not a spatial reference object.
Then I tried to do this :
SR = arcpy.SpatialReference(arcpy.GetParameterAsText(1))
But you get an error because SR objects can only be created using :
1. Get them from a describe object
2. The WKID of the SR
3. A path to a projection file.
You cannot use a text string.
The answer turned out to be :
SRtxt = arcpy.GetParameterAsText(1)
SR = arcpy.SpatialReference()  # an empty spatial reference object
SR.loadFromString(SRtxt)
Phew....
Now on with the rest of it....
BlakeTerhune
Interesting little tidbit. Thanks for sharing.
Luke_Pinner
MVP Regular Contributor
Did you try arcpy.GetParameter(1) instead of GetParameterAsText? GetParameter returns the parameter as an object instead of a string.
NeilAyres
I did try GetParameter, same result, it doesn't return a SR object, but a string!
I looked and looked through the documentation and found no pointers how to do this.
If the esri folk are listening, perhaps something should be in in the help files on how to do this.
My solution works, but is there another way to do it?
NeilAyres
Oh, and another thing...
How do you get the advanced editor when starting a new thread so that you can do the code formatting correctly?
XanderBakker
Esri Esteemed Contributor
If you start a new discussion you should already be in the advanced editor.
XanderBakker
... with respect to the coordinate system, remember that coordinate system and spatial reference are not the same. Look at the following tool, where a coordinate system and a spatial reference can be specified (both using the same interface!):
If the script for this tool is:
import arcpy
crdsys_astext = arcpy.GetParameterAsText(0)
crdsys_assobject = arcpy.GetParameter(0)
sr_astext = arcpy.GetParameterAsText(1)
sr_assobject = arcpy.GetParameter(1)
arcpy.AddMessage("crdsys_astext  : {0}".format(crdsys_astext))
arcpy.AddMessage("crdsys_asobject: {0}".format(crdsys_assobject))
arcpy.AddMessage("sr_astext      : {0}".format(sr_astext))
arcpy.AddMessage("sr_asobject    : {0}".format(sr_assobject))
then this would output:
Start Time: Tue Mar 10 22:55:26 2015
Running script Script...
crdsys_astext  : PROJCS['RD_New',GEOGCS['GCS_Amersfoort',DATUM['D_Amersfoort',SPHEROID[' ... etc
crdsys_asobject: PROJCS['RD_New',GEOGCS['GCS_Amersfoort',DATUM['D_Amersfoort',SPHEROID[' ... etc
sr_astext      : PROJCS['RD_New',GEOGCS['GCS_Amersfoort',DATUM['D_Amersfoort',SPHEROID[' ... etc
sr_asobject    : <geoprocessing spatial reference object object at 0x181E6E78>
Completed script Script...
So, to get the sr object, you should define the parameter as spatial reference and read it as object, not as text.
NeilAyres
Xander,
see this..
My code
# test spatial reference
import sys, os
import arcpy
SR = arcpy.SpatialReference(arcpy.GetParameter(0))
msg = "Coord sys is {}".format(SR.name)
print msg
arcpy.AddMessage(msg)
XanderBakker
... and if you change the definition of the parameter type to spatial reference (instead of coordinate system)?
NeilAyres
Did that, still doesn't work.
If you look at your code above, you are printing the contents of the variable.
Its still not an SR object.
