The order of my coded values are unsorted when adding a new feature in the Collector app.
4313
03-09-2015 01:52 PM
PaigeLester1
The order of my coded values are appearing differently or "out of order" when adding a new feature in the Collector app as compared to the the web map it is referencing. The symbolized values are in the correct "sorted" order in ArcMap when sharing the feature service and also in the saved web map. This behavior in Collector is not logical or desirable. Why is this happening?
Tags (1)
DanPatterson_Retired
apparently information is being stored in a dictionary which is an unordered collection
Kylie
by Esri Regular Contributor
Hi Paige -- In ArcGIS Online, if you click edit, does the order the values are showing in there match what you are seeing in Collector? The Legend uses a different order than editing does.
Esri Education Team
PaigeLester1
Yes, Kylie, that solved it. Thank you.
