error deleting map service with Python/ServerAdmin API - Arc Server 10.2
4001
03-02-2015 07:02 AM
deleted-user-ugCMpXci8bn5
I am trying to delete a map service on ArcGIS 10.2 for Server using Python 2.7 and the ArcGIS for Server Administrator API as shown in this example:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
I have not yet been able to successfully run this script.  I have tried with and without a token.
Below is the traceback in IDLE when I try the example code with a token:
  File "C:\Users\me\Desktop\deleteServices.py", line 24, in <module>
    deleteservice("myserver", "my map service", None, None, 'token_string')
  File "C:\Users\me\Desktop\deleteServices.py", line 18, in deleteservice
    urllib2.urlopen(delete_service_url, ' ').read() # The ' ' forces POST
  File "C:\Python27\ArcGIS10.2\lib\urllib2.py", line 126, in urlopen
    return _opener.open(url, data, timeout)
  File "C:\Python27\ArcGIS10.2\lib\urllib2.py", line 400, in open
    response = self._open(req, data)
  File "C:\Python27\ArcGIS10.2\lib\urllib2.py", line 418, in _open
    '_open', req)
  File "C:\Python27\ArcGIS10.2\lib\urllib2.py", line 378, in _call_chain
    result = func(*args)
  File "C:\Python27\ArcGIS10.2\lib\urllib2.py", line 1207, in http_open
    return self.do_open(httplib.HTTPConnection, req)
  File "C:\Python27\ArcGIS10.2\lib\urllib2.py", line 1177, in do_open
    raise URLError(err)
URLError: <urlopen error [Errno 11004] getaddrinfo failed>
..and here is the traceback when I run the same code without a token:
  File "C:\Python27\ArcGIS10.2\lib\urllib.py", line 88, in urlopen
    return opener.open(url, data)
  File "C:\Python27\ArcGIS10.2\lib\urllib.py", line 209, in open
    return getattr(self, name)(url, data)
  File "C:\Python27\ArcGIS10.2\lib\urllib.py", line 344, in open_http
    h.endheaders(data)
  File "C:\Python27\ArcGIS10.2\lib\httplib.py", line 954, in endheaders
    self._send_output(message_body)
  File "C:\Python27\ArcGIS10.2\lib\httplib.py", line 814, in _send_output
    self.send(msg)
  File "C:\Python27\ArcGIS10.2\lib\httplib.py", line 776, in send
    self.connect()
  File "C:\Python27\ArcGIS10.2\lib\httplib.py", line 757, in connect
    self.timeout, self.source_address)
  File "C:\Python27\ArcGIS10.2\lib\socket.py", line 553, in create_connection
    for res in getaddrinfo(host, port, 0, SOCK_STREAM):
IOError: [Errno socket error] [Errno 11004] getaddrinfo failed
I have been able to run ArcPy functions to create and start map services on this server successfully.
Has anyone successfully used this example code?
