Switching base maps with ArcGISTiledMapServiceLayer
6737
5
02-26-2015 12:39 PM
ChuckBenton
I'm developing an app that runs on both Android and iOS.  My base map comes up just fine, but I want to be able to select between several sources and the solution is eluding me.
The mainMap function includes:
    Item{
          property string source: "http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"
    Map {
        anchors.fill: parent
        wrapAroundEnabled: true
        ArcGISTiledMapServiceLayer {
            url: baseMap.source
Within the main toolBar exists;
            ToolButton{
iconSource: getlayers_icon()
               onClicked: {
                    launchSelectBaseMapMenu()
                    mainMap.reset
                    mainMap.addLayer(baseMap.source)
                    console.log("Resetting Map")
LaunchSelectBaseMapMenu returns an updated baseMap.source, but I cannot identify how to set the TiledMapServiceLayer to the new path.  I've tried doing it directly with ArcGISTiledMapServiceLayer, and moved the reset and other things to various places with no impact.
I'm new to Qt/QML and ArcGIS, so I figure it probably is a simple oversight... any help is appreciated!
Chuck
JeanneTrieu
Hi Chuck,
There is an example of how to do so in our QML sample application under: Tiled Layers->Tiled Layer online. Thank you very much for trying out our beta version. We usually encourage users to post their beta questions on the beta forum however since we will be releasing shortly, we will not move this post to the forum.
thanks,
Jen Trieu | Product Engineer.
JeanneTrieu
Hi Chuck,
thanks,
ChuckBenton
Thanks Jen, it worked fine!
ChuckBenton
I'm having trouble figuring out how to manage layer order.
I'm drawing another layer on top of the base layer as follows:
    Map {
             focus: true
                 url: baseMap.source
        ArcGISDynamicMapServiceLayer {
            url: "http://bv.teamar.com:6080/arcgis/rest/services/UnitedStatesFeatures/MapServer"
            opacity: 0.5
When I change the baseMap as follows (following the guidance given earlier in this post) the layer on top disappears
          ToolButton {
              text: "                "
              Layout.alignment: Qt.AlignHCenter
              Text {
                  text: "Light Gray"
                  font.bold: true
                  color: "black"
              onClicked: {
                baseMap.source = "http://services.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer"
                  tiledMapService = ArcGISRuntime.createObject("ArcGISTiledMapServiceLayer");
                  tiledMapService.url = baseMap.source;
                  console.log("Map:", tiledMapService.url)
                  mainMap.addLayer(tiledMapService);
                  sbmComponent.destroy()
I assume there's a a layer order issue here, but can't find a QML based solution. Any suggestions?
Chuckj
LucasDanzinger
Esri Frequent Contributor
Chuck-
Try using insertLayer instead of addLayer. This allows you to specify the layer index. You can use removeLayerByIndex + insertLayer to switch basemap but leave all other layers as they were. Here is an example of something that seems to work for me for switching basemaps:
ApplicationWindow {
    width: 800
    height: 600
    title: "BasemapSwitcher"
    Map {
            url: "http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"
            url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer"
    ComboBox {
        width: 125
        anchors {
            left: parent.left
            top: parent.top
            margins: 15
        model: ["light grey", "imagery", "topographic"]
    Button {
        anchors {
            left: parent.left
            top: comboBox.bottom
            margins: 15
        width: 125
        text: "switch basemap"
        onClicked: {
            console.log("switching basemap to", comboBox.currentText);
            switch(comboBox.currentText) {
            case "light grey":
                switchBasemap("http://services.arcgisonline.com/arcgis/rest/services/Canvas/World_Light_Gray_Base/MapServer");
                break;
            case "imagery":
                switchBasemap("http://services.arcgisonline.com/arcgis/rest/services/World_Imagery/MapServer");
                break;
            case "topographic":
                switchBasemap("http://services.arcgisonline.com/arcgis/rest/services/World_Topo_Map/MapServer")
                break;
        function switchBasemap(serviceUrl) {
            var lyr = ArcGISRuntime.createObject("ArcGISTiledMapServiceLayer", {url: serviceUrl});
            map.removeLayerByIndex(0);
            map.insertLayer(lyr, 0);
ChuckBenton
Worked perfectly, thanks!!!
