Creating Database View Using ArcMap 10.1 GP Tool
4763
02-26-2015 08:14 AM
IanEvans3
Hi all,
Just wondering if someone can confirm behaviour with using the GP Tool within ArcMap 10.1 for creating a database view.
After running the GP tool, and it sucessfully running, I can now see the view within the SDE database connection. I can drag this into ArcMap, and see the data both spatially and the attribute table. However, if I try and interact with it spatially, such clicking on it with the identify tool then the identify tool does not return a result.
My questions are:
- Is this the expected behaviour?
- And if so, how do I fix this?
I have read other posts regarding regsitering it with SDE etc, but just want to check I am getting the right end of the stick before I ask our DBA to do anything for us.
Thanks in advance for any help!
VinceAngelo
Esri Esteemed Contributor
Due to the extreme limitations of the interface (eliminating all JOIN clauses), 'sdetable -o create_view' should only be used when the geometry storage is SDEBINARY/SDELOB.
Best practice it to create the view elsewhere (as in the GP tool, or via SQL), then use 'sdelayer -o register' to make the view accessible as a simple feature class.
Note that registration will fail if the view does not have a unique, non-zero, positive 32-bit integer column on which to base a USER-set registered rowid column, or if more than one topology class is present (e.g., point and poly).
- V
TinaMorgan1
This is  known issue.  The work around to create views is to use the SDE Command line tools.
AsrujitSengupta
Which database are you using (Oracle, SQL Server, ....)?
Also as Tina suggested, try creating the View using SDE Commandline tool (sdetable -o create_view) and then check the behaviour.
VinceAngelo
- V
IanEvans3
Great, thanks for the support.
I think the idea of us creating the view using the GP Tool and then registering it sounds like a sensible approach for us.
Thanks again everyone!
