Query.Where clause
4857
8
02-25-2015 10:31 AM
WilliamMeredith
The below statement functions fine in a mapserver query:
query.where = "STRU_NAME = '" + structure+ "'";
I'd like to switch the " = " to a like statement.  I can't seem to get this statement to return any data:
query.where = "STRU_NAME like '" + structure+"'";
Any suggestions?  I'm fairly new to development, probably something easy.
Tags (1)
RobertScheitlin__GISP
William,
  Sorry I had my % in the wrong place (% then single quote).
query.where = "STRU_NAME like '" + structure+ "%'"
William,
   This should work:
query.where = "STRU_NAME like '" + structure+ "'%";
You need a wild card in the SQL
WilliamMeredith
Thanks Robert.  I had tried similar syntax changes like you mention but still have no luck, no data gets returned.
Here is the URL (part of it) that with the modification you mention:
query?f=json&where=STRU_NAME%20like%20'wind'%25&returnGeometry=false
This is the original (=, returns data on exact match).
query?f=json&where=STRU_NAME%20%3D%20'wind'&returnGeometry=false
Looks good to me, not sure where the hangup is.
William,
WilliamMeredith
Robert,
Thanks!  Really appreciate your help (the correction above is working great).
Billy
FilipKrál
Some time ago I asked a similar question and I am guessing the same answer applies to you.
Can 10.2 answer Oracle where clause?
Statements with LIKE operator are not standardized queries and they are disabled in 10.2+ by default.
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Hope this explains the issues you are having.
Filip.
FilipKrál
What? How can it work?!? Have you disabled the requirement for standardized queries or does it work out of the box?
Filip.
WilliamMeredith
Filip,
Thanks for the tip, I'll check this out when I have a moment.
Robert,
One last question... if I were to want to add an AND clause to this could you point me in the right direction?
query.where = "STRU_NAME like '" + stateName+ "%' and BMP_TYPE like '" + bmpType+ "%'";
WilliamMeredith
nevermind... answered my own question in that post.  should have tried it first
