What is Error 1935 that occurred during the installation of ArcGIS 10.2.2
10366
5
02-22-2015 02:08 PM
FanXiao
When I installed ArcGIS Desktop 10.2.2 a error occurred as follow:
"Error 1935: An error occurred during the installation of assembly component {943B542A-A22E-38EB-885D-52C90B865DDA}. HRESULT: 0x800736FD."
After I clicked 'OK' the installation rolled back.
Do anyone know the reason of it and help me solve this problem? I really appreciate your help!
Tags (1)
KishorGhatage
JayantaPoddar
Hi Fan,
It seems to be a Low Registry space issue...
Go to Start > Type "regedit"
In Registry editor, go to
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
Key: RegistrySizeLimit
Type: REG_DWORD
Value: 0xffffff (4294967295)
If the problem still persists, you could refer to the Esri Technical Arcticle‌ or contact the Esri Technical Support.
Jay
Think Location
FanXiao
Hi Jayanta,
Thank you so much! It worked to solve the problem. Thanks for your clear and simple solution!
Best,
Fan
DanPatterson_Retired
Fan, I would carefully read the link that Kishor sent, https://community.esri.com/thread/15893#6  since the detailed comments by V Stuart Foote are very useful, simply changing the registry key may not work in all cases
FanXiao
Hi Dan,
Thanks for your help! It is the same method as Jayanta replied and it is the exact solution to my problem.
Best,
Fan
