Spatial Views with Attachments (SQL Server Express 2008 R2)
6373
02-17-2015 01:42 PM
JennB
Hi everyone,
I've successfully created a spatial view of a feature class stored in one of the project's GDBs. However, this particular feature class has attachments and I don't particularly want to lose that information (in fact, we can't! It's needed for the project). My initial question:
  • Can you even maintain attachments using spatial views (so, for example, when you use the Info tool on a polygon from the view you can still see its attachments)
If that's possible, how? I've tried to create a view running the following SQL and the view returns 0 results.
CREATE VIEW BridgeDecks
 AS
 SELECT
  br.OBJECTID,
  br.STR_NAME,
  br.Shape,
  brAtt.REL_OBJECTID,
  brAtt.ATTACHMENTID,
  brAtt.ATT_NAME,
  brAtt.CONTENT_TYPE,
  brAtt.DATA,
  brAtt.DATA_SIZE
 FROM ProjName_Assets.dbo.ProjName_BRIDGEDECKS_MASTER AS br,
  ProjName_Assets.dbo.ProjName_BRIDGEDECKS__ATTACH AS brAtt
 WHERE br.OBJECTID = brAtt.REL_OBJECTID
 AND br.OBJECTID IS NOT NULL;
Any pointers would be just wonderful! Some notes for clarification...
ProjName_BridgeDecks_Master is the feature class
ProjName_BridgeDecks__Attach is the table
ProjName_BridgeDecks__AttachRel is the relationship class that appears in  ArcCatalog, though it's not used in this sql
CarlosKrefft
Where you able to figure this out? I'd like to know the same thing.
by Anonymous User
Not applicable
Attachments are enabled on a feature class, but aren't actually stored in the feature class. There is a relationship class to a table, where the attachments for each feature get stored.
Enabling attachments—ArcGIS Help | ArcGIS for Desktop
I tried to create a view that would preserve attachments (i.e. create a join that adds the BLOB fields from the attachments table to the view), but unfortunately that was not successful. Additionally, it is not possible to create a relationship class from a view to the original attachments table because views aren't registered with the geodatabase
Views in an enterprise geodatabase—Help | ArcGIS for Desktop
Ultimately, attachments are designed to be enabled on feature classes not views.
