Read simplified chinese characters in dbf with codepage file
5902
02-16-2015 02:43 AM
Hsing-JuChang
I have a shapfile with simplified chinese characters.  I added a *.cpg (cp936) and the data displayed correctly in ArcMap 10.2.2
However, when I copied the shapfile with *.cpg to another computer, which was ArcMap 10.1, the data was not showing properly.
Is it possible to use the codepage file in ArcMap 10.1?
Best Regards,
Amy
Tags (1)
DanPatterson_Retired
according to the 10.1 help files, yes, but did you give the *.cpg file the same name as the shapefile?  ie test.shp and test.cpg  ArcGIS Help 10.1
Hsing-JuChang
The cpg file is the same name as the shapefile. Works in ArcMap 10.2.2, but not in ArcMap 10.1
A sample shapefile is attached.
There is at least one article on codepages in the knowledge base, perhaps there were some version changes, but you should have a look at this, sounds like it needs a conversion
ArcGIS 10.2.1 for (Desktop, Engine, Server) Set Shapefile Default Code Page Patch | Samples and Util...
http://support.esri.com/en/bugs/nimbus/role/beta10_1/TklNMTAyMjU5
21106 - Read and write shapefile and dBASE files encoded in various code pages
Hsing-JuChang
Thanks for the info.
I have my user's locale set to Simplified Chinese, and it finally worked in ArcMap 10.1
