Communication between widget.js and widget.html
5633
6
02-11-2015 11:37 AM
TimWitt2
Hey everybody,
If I create a textbox or a button in my widget.html file, how can I access these in my widget.js file?
For example if I create a button in my widget.html file with the id="TestButton", how would I write a button click event in my widget.js file?
Thanks!
Tim
RobertScheitlin__GISP
Tim,
  Use the dojo attach point name and not the dom id.
on(this.button, 'click', lang.hitch(this, function(evt){
    console.log("It is clear!")
Tim,
  Just use
on(this.TestButton, 'click', lang.hitch(this, function(evt){
    //todo
TimWitt2
Thanks Robert,
I get the following error:
fail to open widget Demo. TypeError: Cannot read property 'on' of undefined
Here is what I have in my widget.js
define(['dojo/_base/declare', 'jimu/BaseWidget', 'dojo/dom', "dojo/on",'dojo/_base/lang'],
function(declare, BaseWidget, dom, on, lang) {
  //To create a widget, you need to derive from BaseWidget.
  return declare([BaseWidget], {
    // DemoWidget code goes here
    //please note that this property is be set by the framework when widget is loaded.
    //templateString: template,
    baseClass: 'jimu-widget-demo',
    postCreate: function() {
      this.inherited(arguments);
      console.log('postCreate');
    startup: function() {
      this.mapIdNode.innerHTML = 'map id:' + this.map.id;
      console.log('startup');
    onOpen: function(){
      console.log('It is open, come on in!');
   on(this.clear, 'click', lang.hitch(this, function(evt){
    onClose: function(){
      console.log('onClose');
   var test = this;
    onMinimize: function(){
      console.log('onMinimize');
    onMaximize: function(){
      console.log('onMaximize');
    onSignIn: function(credential){
      /* jshint unused:false*/
      console.log('onSignIn');
    onSignOut: function(){
      console.log('onSignOut');
And here is what I have in my widget.html:
<div>
<button id="clear" data-dojo-type="dijit/form/Button" type="button" data-dojo-attach-point="button">Clear All</button>
</div>
Any ideas what I did wrong?
Tim
Tim,
TimWitt2
Robert works like a charm!
What would I do if I have more than one button and text fields?
Give each control a unique data-dojo-attach-point name. You can also add the event handler stuff directly in the html template.
data-dojo-attach-point="list" data-dojo-attach-event="click:_selectResultItem,mouseover:_overResultItem,mouseout:_outResultItem"
TimWitt2
Thanks Robert that makes sense.
