WMSLayer change transparency in ULR request
6065
5
02-11-2015 07:34 AM
JoachimNitschke1
Hi folks,
I'm using ArcGis Runtime for .NET 10.2.04 to display maps from a WMS server. Instead of a colored background our map always has a white background.
When I check the URL that the Esri framework produces using Fiddler, the result is as following:
GET /?SERVICE=WMS&REQUEST=GetMap&WIDTH=1920&HEIGHT=1080&FORMAT=image%2Fpng&LAYERS=ENC
&STYLES=&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&VERSION=1.3.0&CRS=EPSG:3857&
BBOX=1114445.90347981,7073109.69570739,1210966.09652019,7127402.30429261 HTTP/1.1
As you can see, the request sent to the server has set "TRANSPARENT=TRUE". I need to change this to FALSE otherwise the server returns an image with a transparent background. How do I change this property in XAML or code? Setting the opacy property on the layer doesn't change the URL-request.
Kind Regards,
Eugen
DominiqueBroux
Esri Frequent Contributor
This property is not exposed by the API, so there is unfortunately no mean to change it.
We'll consider that for a future version.
DominiqueBroux
dotMorten_esri
Esri Notable Contributor
As a workaround you could try and set the format to JPEG which doesn't support transparency. We assume that if you're using PNG that you are interested in using the transparency that format offers.
DominiqueBroux
Great idea
JoachimNitschke1
Thanks for the tip! Indeed a nice idea. Sadly it didn't solve the problem. The Jpegs are rendered with a white background according to the request paramter "BGCOLOR=0xFFFFFF".  I guess this parameter isn't exposed by the API either..?
Kind regards
Joachim
DominiqueBroux
I confirm that it's not exposed by the API either. Sorry.
