how to update field with name of FC for list of FCs ?
8059
16
02-10-2015 02:49 PM
GabrielBacca-Cortes
Hi Everybody -
I am trying to fill in the attribute in a newly created field 'Particle', with the name of the FC, which will be changing for a list of FCs. I've tried using 'CalculateField', with which I get the error: 'NameError: name 'xy_1' is not defined', where 'xy_1' is the name of the FC going through the loop.
I've tried using 'UpdateCursor' and I get the error: "  'list' object has no attribute 'setValue'  ".
This is the code I've written so far:
fieldName1 = "Particle"
fieldType1 = "TEXT"
fieldlength = 20
wildcard = ""
fctype = ""
try:
    fcList =  arcpy.ListFeatureClasses(wildcard, fctype)
    # print fcList2
    for fc in fcList:
        print fc
        arcpy.AddField_management(fc,fieldName1,fieldType1,"","",fieldlength,"","NULLABLE")
[with:]
        desc = arcpy.Describe(fc)
        val = desc.name
        print val
        arcpy.CalculateField_management(fc, fieldName1, val, "PYTHON_9.3")
[OR:]
##        curs =  arcpy.da.UpdateCursor(fc,fieldName1)
##        for row in curs:
##            desc = arcpy.Describe(fc)
##            val = desc.name
##            print val
##            row.setValue(fieldName1,val)
##        curs.updateRow(row)
##        del curs, row
XanderBakker
Esri Esteemed Contributor
You could do something like this (if you have ArcGIS 10.1 SP1 or higher):
import arcpy, os
# settings for field
fld_name = "Particle"
fld_type = "TEXT"
fld_length = 20
# set you workspace (where the fc's are located)
ws = r"C:\Path\To\Your\Folder\or\fgdb.gdb"
arcpy.env.workspace = ws
fcs =  arcpy.ListFeatureClasses()
for fc_name in fcs:
    fc = os.path.join(ws, fc_name)
    # add field, if it doesn't exist
    if len(arcpy.ListFields(fc, wilc_card=fld_name)) == 0:
        arcpy.AddField_management(fc, fld_name, fld_type, field_length=fld_length)
    with arcpy.da.UpdateCursor(fc, (fld_name)) as curs:
        for row in curs:
            row[0] = fc_name
            curs.updateRow(row)
    del curs, row
JoshuaBixby
MVP Esteemed Contributor
Review the documentation on ArcPy Data Access cursors.  The arcpy.da update cursor doesn't have a setValue method, that was for the older-style update cursor.  You are effectively mixing up the syntax for the two types of cursors.
GabrielBacca-Cortes
Thanks Joshua -  Yes, you're right I was mixing up 'da' cursors with the older version.
JoshuaBixby
With CalculateField_management, try removing "PYTHON_9.3".  You aren't actually passing an expression, just a value.
TomSellsted
Gabriel,
It look like you may be confusing how you are using cursors in python.  The Data Access module cursors have some distinct differences.  You don't need to specify the field for your cursor.  This might work:
        curs =  arcpy.UpdateCursor(fc)
        for row in curs:
            val = desc.name
            print val
            curs.updateRow(row)
        del curs, row
Notice that I have removed the .da. from your cursor reference and indented the updateRow line.
Regards,
Tom
GabrielBacca-Cortes
Hi Tom -  thanks for the response.  Yes, I was mixing 'DA' cursors with the older version.
the changes worked.
regards,
Gabriel
TomSellsted
You are welcome Gabriel!
XanderBakker
import arcpy, os
fld_type = "TEXT"
fld_length = 20
for fc_name in fcs:
        for row in curs:
            row[0] = fc_name
            curs.updateRow(row)
    del curs, row
GabrielBacca-Cortes
thanks Xander - this works too, for a more general case.  Thanks again..
GabrielBacca-Cortes
Xander -  this general version works great when one has to re-run the script through the same set of FCs without redoing previous work. I am sure you knew this but I just figured it out, 🙂  Thanks a bunch !
