using a web service to populate sparse data
5987
02-06-2015 03:57 AM
EricEagle
Hi, I am nothing but a wee baby when it comes to python, know some ultra-simple things to make repetitive tasks faster. But I need some help and googling hasn't gotten me any really usable results yet.  Probably I'm just not using the right vocabulary.
I frequently have to go through piles and piles of sparse data and fill in missing values.  Generally this requires querying over the web using a known value or two.  This query service has a REST endpoint and would be a good candidate for automating, I think.
If anyone has any snippets of code that would:
  • Take a value from a particular field in a feature class (say, EVENT ID)
  • Send that value as an argument to a base URL (for example, http://www.some_gis_service.com/lookup/<EVENT ID value extracted from field>/details)
  • Look through the XML return and find a particular tag (for example, <DATE>2014-01-01T03:00:00</DATE>)
  • update a field with that value (or some parsing thereof)
Does this make sense?  I'd probably want to build in some sort of dependency or pause between calls so that I don't overwhelm the server.
Thanks for any help!
Eric
PaulCrickard
Python for REST.
My blog explains the code in detail here: ESRI REST and Python: pandas.DataFrame | Architecture and Planning
import urllib, urllib2
import simplejson
param = {‘where':’1=1′,’outFields':’*’,’f':’json’}
url = ‘http://coagisweb.cabq.gov/…/APD_Incidents/MapServer/0/query ?’ + urllib.urlencode(param)
rawreply = urllib2.urlopen(url).read()
reply = simplejson.loads(rawreply)
print reply[“features”][0][“attributes”][“date”]
print reply[“features”][0][“attributes”][“CVINC_TYPE”]
XanderBakker
Esri Esteemed Contributor
If you want some python examples of how to extract features from a REST end point using python, you can find some in this thread: Re: Extract Features From MapServer/ Rest/ Soap/ etc?  Jake Skinner created a toolbox to do this.
There are also references to some python code I wrote to do this:
the simple way:https://community.esri.com/thread/118781#445348‌
or using a little more advanced:https://community.esri.com/thread/118781#445572
You can find an example of updating a feature service through Python and REST here:
Re: UpdateFeature REST API Python Script Unexpected Error
Filip Kral mentions an interesting Python client for ArcGIS for Server and this post (Loading ArcGIS REST Service data into Excel ) by Marc Hoogerwerf is worth reading too.
Kind regards, Xander
EricEagle
Thanks Xander!  Since reading this I have a script now that uses a dictionary to store results and then query that first before going out and hitting the service.  Thanks for the links,
Eric
XanderBakker
Sounds good! If you are willing to share this with the community it would be great.
