Configuring Overview Map in WAB
4741
02-06-2015 05:32 AM
TunaUnsal
Hi, Although the title says configuring, it doesn't seem possible to configure the Overview Map at all. Sure we can define the size of the window but it would really make sense if we could work on the content as well.
Normally the content of this widget is the base map you use in your map. This makes the widget useless for my case since I use just the imagery as a basemap with all other details (places, roads etc.) coming from operational layers. So I just see a satellite image in the overview map which is not helping at all.
While digging to find a solution I found out that when I add a new base map with 2 web services included, the overview map uses just the one on the top but not the one on the bottom. So I created a base map, added an extra basemap layer, put the world imagery on the bottom and added an in-house published map service (a low-res imagery and fit for purpose reference layer) on the top.
As a result the overview map only shows my published service while this service  is hidden under  world imagery in the base map displayed on the main map.
As it is far from being an ideal solution can anyone give me an advice on how to solve this issue?
TunaUnsal
Please note that I am working on Portal for ArcGIS but not AGOL.
RobertScheitlin__GISP
Tuna,
    The OverviewMap in WAB uses the esri OverviewMap dijit
OverviewMap | API Reference | ArcGIS API for JavaScript
If you look at the documentation the dijit only uses the basemap specified or if not specified then the main maps basemap. The dijit does not allow for adding additional layers.
