So far I got this far:
import arcpy
from arcpy import env
env.workspace = r"C:\SouthA\Bolivia.gdb"
listFCs = arcpy.ListFeatureClasses("*")
for fc in listFCs:
rows = arcpy.UpdateCursor(fc, , , ["field1", "field2", "field6", "field7"])
for row in rows:
if row.getValue() == 0:
rows.deleteRow(row)
The idea is that in each table select and delete the rows which have "0"s in either/or field1, field2....
Ert
For starters, I encourage you to read up on the Arcpy Data Access module (arcpy.da). The cursors in the data access module are newer, more robust, and higher performing than the older cursors.
I gotta step out but will post some code when I get back if someone hasn't already.
Haven't tested, but try:
import arcpy from arcpy import env env.workspace = r"C:\SouthA\Bolivia.gdb" listFCs = arcpy.ListFeatureClasses("*") for fc in listFCs: with arcpy.da.UpdateCursor(fc, ["field1", "field2", "field6", "field7"]) as cur: for row in cur: if 0 in row: cur.deleteRow()
Instead of checking each row to see if it meets the condition, could you only bring back the rows that meet the condition and delete them all?
import arcpy arcpy.env.workspace = r"C:\SouthA\Bolivia.gdb" listFCs = arcpy.ListFeatureClasses("*") field_names = ["field1", "field2", "field6", "field7"] where_clause = "field1 = 0 OR field2 = 0 OR field6 = 0 OR field7 = 0" for fc in listFCs: with arcpy.da.UpdateCursor(fc, field_names, where_clause) as cur: for row in cur: cur.deleteRow()
That is another approach. Although I like working with SQL, building SQL expressions via Python and passing them to Esri tools seems to be a hang up for lots of folks, so I decided against suggesting a where_clause, but it will work.
Thanks Guys,
Both ideas worked!
