Python script to field calculate one field based on another field's value
5484
02-05-2015 06:17 AM
SusanO_Connell
I would like to find a python script to field calculate one field based on another field's value.  For example, "Field B" will have a code '23' if "Field A" is equal to CST, or if it is equal to AFF, it will be '11'. Also need to know what to use as a wildcard if CST or AFF is followed by more descriptions.
Tags (1)
MahtabAlam1
It will require a code block which is nothing but a python function. Please refer Calculate Field Examples
So all you need is something like
def cal( valA):
    if(valA.startswith('CST') or valA.startswith('AFF')):
        return 11
    else:
        return
and call it as
cal(!Field_A!)
Hope that helps.
MahtabAlam1
def cal( valA):
        return 11
    else:
        return
and call it as
cal(!Field_A!)
Hope that helps.
SusanO_Connell
Thank you very much!
Susan O’Connell
Geographic Information Systems
GIS Specialist
XanderBakker
Esri Esteemed Contributor
Hi Susan O'Connell‌,
If your the solution provided by Mahtab Alam‌ solved your problem (and I think it did), could you please mark his answer as the correct one.
Thank you,
Xander
GeoNet Moderator
XanderBakker
Hi Susan O'Connell,
I think you ment to mark the answer by Mahtab Alam as helpful, right? Since you marked your own response as helpful.
