Empty Numeric Fields by Default?
4717
02-04-2015 05:17 AM
FrancisSenyah
When working with numeric fields in the App (float, long or short integer for instance..) it seems you can not have a field open as empty by default, it is always populated by a value.  This is fine where a range is set but otherwise it can mean a lot more time in the field as the process of deleting and re-entering a value is time consuming.  Is it not possible to have an empty numeric field by default ?  I am aware that text fields can be empty by default on opening.
Thanks, Francis.
RussRoberts
Esri Notable Contributor
numeric fields can be empty but if you have the fields set to required you will see a 0. If you got to the feature service REST endpoint and look at the template you will see in the template the numeric fields will have a value of 0 and the app leverages the template information when collecting and editing features from that service.
Russ
RussRoberts
Russ
FrancisSenyah
Thanks Russ I wasn't aware of the 'required' option.  This answers my query - many thanks!
