FeatureLayer from ShapeFile, change Fill-Color
4889
02-03-2015 08:37 AM
DannyNieruch
I am creating a FeatureLayer from a Shapefile on my map with the following code at application startup :
public async void LoadShapefileAsync(string path)
    try
        ShapefileTable shapefile = await ShapefileTable.OpenAsync(path);
        _spatialReference = shapefile.SpatialReference;
        GisMap.SpatialReference = _spatialReference;
        FeatureLayer flayer = new FeatureLayer(shapefile)
            ID = shapefile.Name,
            DisplayName = path,
        GisMap.Layers.Add(flayer);
    catch (Exception ex)
        throw new ArgumentException("Feature-Layer aus Shapedatei konnte nicht erstellt werden: " + ex.Message);
The result on my map is a grey filled polygon with a black solid outline.
How can I change the fill color and outline style for the polygon(s) on the FeatureLayer?
Thanks in advance! 🙂
dotMorten_esri
Esri Notable Contributor
The Shapefile layer will render with this default renderer. You can assign your own renderer to it, either Simple-, Unique- or ClassBreaksRenderer. Example
flayer.Renderer = new SimpleRenderer() { Symbol = new SimpleFillSymbol() { Color = Colors. Red } };
dotMorten_esri
DannyNieruch
Works like a charm!
Many thanks
