XML 'library' error
3694
01-29-2015 01:21 PM
BBulla
I'm migrating a bunch of 9.3 tools to 10.2 AddIns.  Is there a restriction on the length of the .dll that the AddIn creates?  I'm getting a few errors on building a project, and the AddIn is not registering with ArcMap.
The error is:
Warning1Custom tool warning: The 'library' attribute in the AddIn element may be invalid - The value  'Facility_ID_Tool__AddIn.dll' is invalid according to the project output assembly name 'Facility_ID_Tool _AddIn.dll'.C:\Visual Studio Projects\Facility_ID_Tool _AddIn\Facility_ID_Tool _AddIn\Config.esriaddinx1325Facility_ID_Tool _AddIn
Here is the XML:
<AddIn language="CLR" library="Facility_ID_Tool__AddIn.dll" namespace="Facility_ID_Tool__AddIn">
This was all setup using the Wizard in VS2012.
Thanks.
BBulla
By length I mean the length of the filename.
GregMcQuat
Let's try to solve this one for you since we're not having any luck on the COM Exception!
vs.
There are 2 underscores before AddIn in the first and one in the second.
BBulla
Thanks Greg.  Yeah, I'm not sure what happened here.  Basically I just re-built the add-in from scratch and had no problems.  Not sure if it was a problem with length of name or what, but eventually I got it working.
