feature class used in map services
4746
01-28-2015 02:39 PM
MarceloVillarroel1
Is there a way to know which map services (in ArcGIS Server) are using some individual feature class (in file geodatabase)?
The purpose is to know which services I need to stop in ArcGIS Server Manager before editing that feature class.
JakeSkinner
Esri Esteemed Contributor
Make sure you are connecting to ArcGIS Server as an admin.  You will then should have this option.
JakeSkinner
Hi Marcelo,
If you right-click on the service > Service Workspaces, it will list the feature classes the Map Service is using.
MarceloVillarroel1
Hi Jake,
I have no Service Workspaces-window at right-click on the service. I´m using ArcGIS Desktop 10.2 and ArcGIS for Server 10.0. Services are running well.
Thank you for your help.
JakeSkinner
MarceloVillarroel1
You are right. Thanks a lot.
