How to access ArcMap Options using ArcObjects?
5321
01-26-2015 03:53 AM
BarbaraSchneider1
Is there a way to access the ArcMap Options using ArcObjects (In ArcMap select  Customize - ArcMap Options)?
nicogis
for example for cad:
//Set CadSettings to a new CadWorkspaceFactory.
ESRI.ArcGIS.DataSourcesFile.ICadSettings pCadSettings = new
    ESRI.ArcGIS.DataSourcesFile.CadWorkspaceFactory()as
    ESRI.ArcGIS.DataSourcesFile.ICadSettings;
//Enable support to examine all files for DGN format.
pCadSettings.EnableAllDgnFileExtensions = true;
//Print the results to the console.
Console.WriteLine("EnableAllDgnFileExtensions = {0}",
    pCadSettings.EnableAllDgnFileExtensions);
or for example hardware acceleration (IGlobalScreenDisplaySettings ) :
ArcObjects Help for .NET developers
see Interface *Settings
What's the setting that you need change?
BarbaraSchneider1
I need to change the raster layer settings. However, I cannot find IRasterLayerSettings or similar.
nicogis
