How to set spatial reference to a schematic diagram class with Arcobjects?
7982
10
01-27-2015 02:35 AM
KevinLECOCQ
I used ArcObjects for .NET to create a schematic dataset, then a schematic diagram class (aka "schematic template" in the UI) wherein I load feature classes.
To do that, I followed the sample: "Create A Standard Builder Schematic Diagram Class From Scratch".
But when I generate diagrams, I get from ArcMap a "missing spatial reference" warning.
So how to set the spatial reference?
In ArcMap, it's possible in the properties of the schematic template. But using ArcObjects, I can't find an interface of the class SchematicDiagramClass to set the ISpatialReference.
I would appreciate any help on that.
Thanks!
nicogis
nicogis
SchematicDiagramClass implements IGeoDataset ArcObjects Help for .NET developers  that has SpatialReference ArcObjects Help for .NET developers
KevinLECOCQ
Yes, but the spatial reference property of IGeoDataset is read-only: http://resources.arcgis.com/en/help/arcobjects-net/componenthelp/index.html#//0025000003n0000000
There is only a "get" to the spatial reference object.
nicogis
see IGeoDatasetSchemaEdit ArcObjects Help for .NET developers
KevinLECOCQ
It works casting the ISchematicDiagramClass object to this IGeoDatasetSchemaEdit, then using AlterSpatialReference, thanks.
Now I still have a 'missing spatial reference' error adding a diagram to a map, because the schematic element classes still don't have spatial reference. I create these object as ISchematicElementClass. What interface could I use to set their spatial reference?
nicogis
You can get SchematicDataset and then alter spatial reference
KevinLECOCQ
OK, I got the ISchematicDataset object and am looking for an interface like IGeoDatasetSchemaEdit to change the spatial reference. The available interfaces are in this list: ArcObjects 10 .NET SDK Help
IGeoDatasetSchemaEdit isn't available for this object because I get a cast error.
Which interface could I use ?
nicogis
Can you post part of source code ?
KevinLECOCQ
I can't cast the SchematicDataset to IGeoDatasetSchemaEdit because I get an InvalidCastException. Here is my code:
I create a schematicWorkspace from a IWorkspace like this:
ISchematicWorkspaceFactory schematicWorkspaceFactory = new SchematicWorkspaceFactoryClass();
ISchematicWorkspace schematicWorkspace = schematicWorkspaceFactory.Open(workspace);
Then, I create the schematic dataset:
schematicDataset = schematicWorkspace.CreateSchematicDataset(SCHEMATIC_DATASET_NAME);
schematicDataset.DesignMode = true;
Type objectType = Type.GetTypeFromProgID("esriSchematic.SchematicStandardBuilder");
ISchematicStandardBuilder schematicStandardBuilder = Activator.CreateInstance(objectType) as ISchematicStandardBuilder;
schematicStandardBuilder.AddConnectedNodes = true;
schematicStandardBuilder.InitializeLinksVertices = true;
schematicStandardBuilder.AutoCreateElementClasses = true;
schematicDiagramClass = schematicDataset.CreateSchematicDiagramClass(SCHEMATIC_DIAGRAM_CLASS_NAME);
schematicDiagramClass.SchematicBuilder = schematicStandardBuilder as ISchematicBuilder;
schematicDiagramClass.SchematicDataSource = schematicDataset.DefaultSchematicDataSource;
schematicDiagramClass.ExternalQueryEvaluationMode = esriSchematicExternalQueryEvaluationMode.esriSchematicNoQuery;
schematicDiagramClass.AlwaysLoadDiagrams = true;
Then, I define the spatial reference:
ISpatialReference spatialReference = gdbDataset.getSpatialReference();
IGeoDatasetSchemaEdit geoDataset = (IGeoDatasetSchemaEdit)schematicDataset; // here I get an InvalidCastException
geoDataset.AlterSpatialReference(spatialReference);
IGeoDatasetSchemaEdit geoDiagramClass = (IGeoDatasetSchemaEdit)schematicDiagramClass;
geoDiagramClass.AlterSpatialReference(spatialReference);
nicogis
Excuse me but before I have seen old help because now schematic has changed ( ArcObjects Help for .NET developers ). See these snippets: http://www.arcgis.com/home/item.html?id=a8be26357b944dfdbbd69a55818dcc88
