arcgis desktop search tool not workiing
4967
01-24-2015 02:51 AM
ManeshSharma
hi
The search tool in arcmap is not working in win xp sp3. while it is opening in arc catalogue.
the version of arcgis desktop 10.2.2
XanderBakker
Esri Esteemed Contributor
The search is working just fine in ArcMap 10.2.2.3552 on Windows 8.1. Support for XP ended April last year. Might be wise to consider updating the os...
DanPatterson_Retired
Skip the built-in help...if you have web access while working in ArcMap, use the online help for 10.2.x    And help for 10.3 you may as well start looking at this link it is faster, more up-to-date than the built-in
curtvprice
Found a fix for this issue on the support site
Problem: The Search window in ArcMap does not return any results
XanderBakker
Nice to know there is a fix available after 5 years... Thanks for sharing Curtis.
