org.apache.http.conn.HttpHostConnectException: Connection to http://services.arcgisonline.com refused
8105
01-22-2015 05:41 AM
AkshathaRaju
I am using ArcGIS_Runtime_Java_Samples_10.2.4_win32, and I am trying to launch the sample application on Windows by,
Navigate to 'Start Menu > All Programs > ArcGIS > Runtime SDK 10.1.1    for Java > ArcGIS Runtime Java Samples 10.2.4'. When I am opening this sample, few maps are being displayed but few of them are not. For instance when I am trying to view Basic Map under Map, I get the following error in Console
- - - Executing sample com.esri.client.samples.map.SimpleMap - - -
javax.imageio.IIOException: Can't get input stream from URL!
at javax.imageio.ImageIO.read(Unknown Source)
at com.esri.client.samples.map.SimpleMap.createUI(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.esri.client.samples.j.a(Unknown Source)
at com.esri.client.samples.SampleViewer$2.valueChanged(Unknown Source)
at javax.swing.JTree.fireValueChanged(Unknown Source)
at javax.swing.JTree$TreeSelectionRedirector.valueChanged(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.fireValueChanged(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.notifyPathChange(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.setSelectionPaths(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.setSelectionPath(Unknown Source)
at javax.swing.JTree.setSelectionPath(Unknown Source)
at com.esri.client.samples.SampleViewer$8.mouseClicked(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$300(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: java.net.ConnectException: Connection timed out: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.net.URL.openStream(Unknown Source)
... 47 more
org.apache.http.conn.HttpHostConnectException: Connection to http://server.arcgisonline.com refused
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:127)
at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:147)
at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:108)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:415)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:641)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:731)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:709)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:700)
at com.esri.core.internal.io.handler.h.a(Unknown Source)
at com.esri.core.internal.tasks.ags.t.a(Unknown Source)
at com.esri.core.internal.tasks.ags.t.execute(Unknown Source)
at com.esri.map.Layer.loadServiceInfo(Unknown Source)
at com.esri.map.Layer.getMapServerInfo(Unknown Source)
at com.esri.map.ArcGISTiledMapServiceLayer.internalInit(Unknown Source)
at com.esri.map.Layer$1.run(Unknown Source)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
at org.apache.http.conn.scheme.PlainSocketFactory.connectSocket(PlainSocketFactory.java:123)
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:123)
... 20 more
Why is it working for only few maps? Can anybody please help me on this
Tags (1)
