Add a multi Layer files to mxd using python
7370
6
01-19-2015 01:57 AM
Yaron_YosefCohen
Hello
I have more than 300 layer files located in many sub-Folders and sub-sub-Folders. All Sub Folders are located in one large directory.I read http://gis.stackexchange.com/questions/35693/use-python-to-add-layers-to-toc?rq=1
and I try, with arcpy, to detect all the layers and add them to mxd.
Is it possible?
Tags (3)
XanderBakker
Esri Esteemed Contributor
First of all you should really use syntax highlighting: Posting Code blocks in the new GeoNet
To recursively loop through folder and sub folder and detect the layerfiles (.lyr) you can use the arcpy.da.Walk functionality (asuming you have a recent version of ArcGIS).
import arcpy
import os
workspace = r"D:\Xander\GeoNet"
walk = arcpy.da.Walk(workspace, datatype="Layer")
for dirpath, dirnames, filenames in walk:
    for filename in filenames:
        print (os.path.join(dirpath, filename))
This prints each .lyr file it finds:
D:\Xander\GeoNet\StackedLabels\aLayer.lyr
D:\Xander\GeoNet\StackedLabels\subfolder\subsubfolder\subsubsubfolder\AnotherLayer.lyr
In case you want to add all the layer found to an existing MXD you should open the MXD before the loop and add put the add layerfile logic inside the loop. Adding a lot of layer to an MXD will probably make it very slow.
Your code might look like this (in case you run this inside a session of ArcMap and want to add the layers to the current session of ArcMap, hence the keyword "CURRENT"):
import arcpy
import os
# suppose you want to add it to the current MXD (open MXD)
mxd = arcpy.mapping.MapDocument("CURRENT")
dataFrame = arcpy.mapping.ListDataFrames(mxd, "*")[0]
# base folder
        layerfile = os.path.join(dirpath, filename)
        addlayer = arcpy.mapping.Layer(layerfile)
        arcpy.mapping.AddLayer(dataFrame, addlayer, "BOTTOM")
arcpy.RefreshTOC()
arcpy.RefreshActiveView()
del addlayer, mxd
In case you want to run it as a standalone script and/or add the layers to a different existing MXD, you should replace the keyword "CURRENT" on line 5 by a reference (string containing path and filename) to the MXD.
KishorGhatage
I believe it is possible.
Search the layer using .lyr extension in the directory and then use Add layer to add the searched lyr in MXD.
Add layer
http://resources.arcgis.com/en/help/main/10.2/index.html#//00s300000025000000
import arcpy, os
folderPath = r"C:\Project"
for filename in os.listdir(folderPath):
    fullpath = os.path.join(folderPath, filename)
    if os.path.isfile(fullpath):
        basename, extension = os.path.splitext(fullpath)
        if extension.lower() == ".mxd":
            # Use Add layer here
            mxd.save()
del mxd
In the  above code .mxd files are searched. Using  the same code you can search your .lyr and add then in the desired mxd.
I am not python expert. Hope this information is helpful.
XanderBakker
import arcpy
import os
import arcpy
import os
# base folder
arcpy.RefreshTOC()
del addlayer, mxd
KishorGhatage
Thanks Xander. It's very helpful.
Yaron_YosefCohen
Hello
I cant find the >> sign so the code will marked...
i run this code and nothing happend. the first code is working
what to do now?
import arcpy
import os
mxd = arcpy.mapping.MapDocument(r"C:\Project\Project.mxd")
# base folder
workspace = r"C:\Project\layers"
arcpy.RefreshTOC()
del addlayer, mxd
KishorGhatage
Just added save statement
import arcpy
import os
# base folder
        mxd.save()
arcpy.RefreshTOC()
del addlayer, mxd
Yaron_YosefCohen
the code added just 2 lyr.file in the workspace. it didn't added the lyr in the sub folders
