Basic Question
4065
6
01-06-2015 11:46 AM
RoyTarantino
HI,
I'm a newbie to ArcGIS so I'm sure this is a very basic question.  I'm trying to plot a single lat, lon point with ArcMap from a csv file.  I created the csv file from excel:
IDLongitudeLatitude
VZW-74.533958333
40.725025000
It contains the lat lon of an location in Basking Ridge, NJ (gotten from Goggle earth).  When I load it into ArcMap, it displays the point off the coast of Africa in the the Atlantic Ocean!
What am I doing wrong?  Here are the steps:
1. Create a new document, add basemap STreets
2. click on add data, select my csv file
3. right click on it in the table of contents, select display xy data...
4. DIsplay XY Data pop up appears with:
X Field Longitude
Y Field Latitude
Z field <None>
Projected Coordinate System:
Geographic Coordinate System:
Click ok, and the symbol appears off of Africa.
When I take the same XY value and click on Go To XY, and enter it in the fields, ArcMap locates it correctly,.
Eventually I need to plot many lat lons from a gps device all in csv files.
Please help!
Roy
AnthonyGiles
Honored Contributor
Roy,
if your coordinates are geographic (lat/long) you need to use a geographic projection. Under geographic-world-wgs84
regards
anthony
TimWitt2
Roy,
- open an mxd
-click on file -> add data -> add xy data
and switch your x and y.
this should work.
Tim
AnthonyGiles
Honored Contributor
Roy,
regards
anthony
RoyTarantino
BINGO! That was it. Thanks so much.
I was confused by the wgs84
-Roy
RoyTarantino
AnthonyGiles
Honored Contributor
Ray,
Please don't forget to also mark the post as answered,
regards
Anthony
RoyTarantino
Done. Thanks again.
