Arc Objects Spatial analyst Con Condition
4327
01-04-2015 04:24 AM
NadirHussain
If inRaster < inputnumber1 Then
   outRaster = 1
ElseIf inRaster > inputnumber2 Then
   outRaster =0
ElseIf inRaster >= inputnumber1 and   inRaster<= inputnumber2 Then
    outRaster = 0.5 * (1 + cos(3.14159*((inRasterinputnumber1 )(inputnumber2 - inputnumber1 ))))
Else
outRaster = 0
The above statments i have to make in arcobjects by using spatial analyst.I am totally confused.Please help.How to make condition in IConditionalop of  spatial analyst.Any help will be appreciated.
Thanks in Advance.
Regards
XanderBakker
Esri Esteemed Contributor
If you would use this Con statement manually in the Raster Calculator, it would probably look something like:
Con(inRaster < inputnumber1, 1, Con(inRaster > inputnumber2, 0, Con((inRaster >= inputnumber1) AND (inRaster<= inputnumber2), 0.5 * (1 + cos(3.14159 * ((inRaster – inputnumber1) * (inputnumber2 - inputnumber1)))), 0)))
Since you're using ArcObjects, things will get a bit more complicated to nest the Con Statements. Maybe you can find some useful info here:
ModyBuchbinder
Hi
You can just get the pixels with direct read into array and use any calculation.
Check this: How to access pixel data using the RawBlocks object (ArcObjects .NET 10 SDK)
Mody
