Address locator
4898
01-03-2015 07:48 AM
IvanBodnar
Hi
I have an issue with creating an address locator on arcgis 10.2.2.
I always used an address locator somebody else made, it's made on arcgis 9.2. When I look into its properties, it says Description: US Streets, Style: N/A.
The thing is I made a locator by my own, using the US address dual range style, which I think it's the same as the previous locator. I use all the required fields.
But the new locator takes forever to complete the job, and most of the times it ends up crashing, whereas the old locator keeps working smoothly.
Anybody has a clue on why this could be happening?
Thanks a lot
BruceHarold
Esri Frequent Contributor
Ivan, if you're getting crashes you should log a support call and forward the crash dumps.
You will probably be asked to supply the locator you made (by zipping it up).
Regards
