ArcGIS Server 10.2 post-install/rename AGS virtual server?
3195
12-30-2014 10:02 AM
847396730
Occasional Contributor III
One of the Esri Best Practice articles encourages cloning virtualized images and using post-installs to associate AGS w/the specific machines.  However, I cannot find any ArcGIS Server post-installs for versions after 10, and I'm working with versions 10.2 and 10.2.2.
In this context, I took an image of prod and stuck it on my dev server.  Now I need to adjust everything (application code, map services, IIS) to reference the correct dev server name.
So two questions:
1) is there a post-install for AGS 10.2/10.2.2?
2) is this the correct way to approach this task?
Thank you!
