calculate field fails
5015
12-24-2014 09:29 AM
JustinShepard
I have an IFeatureClass created in my code and I have added a new field to it. I'm stuck on calculating values for the new field. I've tried using CalculateField and ICalculator but I get errors from both (see code below). Any suggestions?
IFeatureClass classifiedPolygons_IFC
IFieldEdit2 field
* Error HRESULT E_FAIL has been returned from a call to a COM component.
* I've also tried casting the IFeatureClass to ITable
CalculateField calculateField = new CalculateField()
    in_table = classifiedPolygons_IFC,
    field = classifiedPolygons_IFC.Fields.Field[classifiedPolygons_IFC.Fields.FindField(field.Name)],
    expression = "Calc Val",
    expression_type = "Python"
Geoprocessor gp = new Geoprocessor();
gp.Execute(calculateField, null);
* "Retrieving the COM class factory for component with CLSID {D676066E-38CA-429A-B846-DA7A8446C52D} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))."
ICursor updateCursor = classifiedPolygons_IFC.Update(null, false) as ICursor;// table.Update(null, false);
ICalculator calculator = new Calculator()
    Cursor = updateCursor,
    Field = field.Name,
    Expression = "Calc Val"
calculator.Calculate();
Marshal.FinalReleaseComObject(updateCursor);
RichardFairhurst
Calc Val is a string and expression is a string variable, but the string must be quoted twice, once for the actual value in the field calucator, and another time for the string variable.  So expression = "Calc Val" won't work, but expression = "'Calc Val'" should work (single quotes inside double quotes work for Python calculations, but not VB Script calculations.  For VB Script it would be expression = """Calc Val""").
ModyBuchbinder
Hi
If
you open an update cursor you should just calculate the values.
Check
the update cursor example (and a few other examples) here: http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/0001/0001000001mm000000.htm
Have
fun
Mody
RichardFairhurst
JustinShepard
I'm on holiday right now but I'll give it a try on Monday and let you know how it goes. Cheers.
JustinShepard
Thanks for catching that. I'm sure I'll be posting more questions as I work through creating my first SOE.
