Using the clipping tool in Arc 10.2.2
1446
12-20-2014 12:35 AM
JemilahErdem
Hi there, Im using Arc Map 10.2.2 and Im having quite a bit of a problem clipping transects from a mid line (hedge mid point) to polygon edges (Hedge outline), when I use clip, the transects sticking outside the polygon remain and the ones I need inside dissappear, can anyone suggest what I'm doing wrong, and if there is another tool or setting I should use, I've only access to Arc 10.2.2 basic with the added spatial analyst tool
I'd be very grateful for any advise.
DanPatterson_Retired
are you trying to "split" the transect? that is subdivide the transect? Try the split tool
