Adding layer
1090
12-18-2014 08:01 AM
BatbayarJargalsaikhan1
I'm trying to add layer to my map.
I can see base map but not added layer. here's my script. what did I wrong?
<script>
      var map;
      require([
        "esri/map",
        "esri/layers/FeatureLayer",
        "dojo/domReady!"
        ], function(Map,FeatureLayer) {
        map = new Map("map", {
          basemap: "satellite",
          center: [106.895, 47.920], // longitude, latitude
          zoom: 16
        var parcelsOnline = new FeatureLayer("http://services.arcgis.com/HJzgwvlNIXssnQar/arcgis/rest/services/Ulas_1215/FeatureServer/0", {
          mode: FeatureLayer.MODE_ONDEMAND,
          outFields: ['*']
      map.addLayer([parcelsOnline]);
    </script>
JakeSkinner
Esri Esteemed Contributor
Hi Batbayar,
Since you are using the addLayer method, you will not want to specify an array.  If you are using the addLayers method, you would then pass an array.  Try the following:
map.addLayer(parcelsOnline);
thanks,
it works now.
