Syntax error using ArcPy Spatial Analyst module in Python
4158
12-14-2014 01:07 PM
JessicaSorrell
I'm very new to using python and figure I'm missing something obvious in the following script.  I keep getting a "syntax error" message no matter how much I fiddle around with the first few lines.  I think it has something to do with calling the spatial analyst module into python while checking out the spatial analyst extension. Any help would be greatly appreciated!
#Script takes an input DEM raster and delineates watershed boundaries based on
# flow direction and accumulation
# Import arcpy module
import arcpy
from arcpy.sa import *
# Check out the Spatial Analyst extension
#Specify the input raster
inDEM = arcpy.GetParameterAsText(0)
#Specify the input coordinate system
spatialReference = arcpy.GetParameterAsText(1)
#Specify the minimum number of cells that are assumed to represent a stream
# (cell threshold)
inMin = arcpy.GetParameterAsText(2)
Try:
    # Process: Project Raster
    arcpy.ProjectRaster_management(inDEM, projectDEM, spatialReference)
    # Process: Fill
    fillDEM = Fill(projectDEM)
    # Process: Flow Direction
    flowDir = FlowDirection(fillDEM, "NORMAL")
    # Process: Flow Accumulation
    flowAccum = FlowAccumulation(flowDir)
    # Process: Raster Calculator
    outRaster = RasterCalculator((flowAccum > inMin))
    # Process: Raster to Polyline
    arcpy.RasterToPolyline_conversion(outRaster, polyLines, "ZERO", "0", "SIMPLIFY", "VALUE")
    # Process: Feature Vertices To Points
    arcpy.FeatureVerticesToPoints_management(polyLines, lineVertices, "END")
    # Process: Watershed
    outWatershed = Watershed(flowDir, lineVertices)
    # Process: Raster to Polygon
    arcpy.RasterToPolygon_conversion(outWatershed, watershedPolygons, "SIMPLIFY", "VALUE")
# Check in the Spatial Analyst extension
arcpy.CheckInExtension("Spatial")
#error handling
except:
    arcpy.AddError("Script failed to write successfully")
    arcpy.AddMessage(arcpy.GetMessages())
JoshuaBixby
MVP Esteemed Contributor
Posting code with syntax highlighting and numbers is useful, as well as specific error messages.  For syntax highlighting, click the 'Use advanced editor' link in the upper right corner of the question/reply.
Do you know whether the Spatial Analyst extension is being correctly checked out?  What is the return value of checking out the license?
Luke_Pinner
MVP Regular Contributor
Your Try: statement is capitalised, it should be lower case try:
DanPatterson_Retired
these 2 lines are incorrectly dedented, they should be within the try block ... also 'try' is lower case
And do format the code using the advanced editor's syntax highlighting
