Customizing the Query Widget
6513
12-15-2014 08:55 AM
MaxMcCosham
I have a question on the customization of a built-in widget in AppBuilder. I have created an app using Web AppBuilder and downloaded the code to work with. Now I would like to modify the Query Widget by adding a few tasks to execute after the user clicks on a query result. For example, I would like to be able to adjust the visibility of other ArcGIS Online web map layers (after user clicks on a result, map zooms to the selected result, then another layer's visibility changes from off to on). Which widget code files would I need to modify to achieve this?
Max
Tags (3)
RobertScheitlin__GISP
Max,
   You would need to obtain the WAB developer version and then modify the widget.js in the client\stemapp\widgets\Query folder
Max,
MaxMcCosham
Thanks Robert for the quick reply!
zhongrenGu
Hi Max ,hava you finished your custom widget??  now i'm create my widget,but i don't konw how to custom the content of widget,for example :write some button on a widget,how to operate the map ;and  how to load my map on my  arcgis server;thanks;
Guzhongren
