ArcGIS .Net Runtime, TextSymbol class issue (Offset)
4555
12-15-2014 12:56 AM
EdL
private LabelProperties InitLabels()
            LabelProperties property = new LabelProperties();
            AttributeLabelClass attrLabel = new AttributeLabelClass();
            attrLabel.TextExpression = string.Format("[{0}]", attributeLabel);
            attrLabel.LabelPosition = LabelPosition.FixedPositionWithOverlaps;
            attrLabel.Symbol = new TextSymbol
                BackgroundColor = Colors.Yellow,
                Color = Colors.Black,
                YOffset = 200
            attrLabel.IsWordWrapEnabled = true;
            attrLabel.WordWrapLength = 30;
            property.LabelClasses.Add(attrLabel);
            return property;
I have a simple method to create a label property to apply to a GraphicsOverlay. After applying the above, the label offset does not seem to be offsetting the labels at all.
A value of 200 should display the label significantly far away from the actual graphic point but no change is noticed. The same method is applied to a GraphicsLayer but no change is seen.
Is there a fix to this?
AsserSwelam1
Hi Ed,
Actually that's a limitation with the AttributeLabelClass. The positioning properties (XOffset , YOffset , Angle and AngleAlignment) is not supported for AttributeLabelClass.Symbol.
Asser
AsserSwelam1
Hi Ed,
Asser
