HydrographicS52DisplayProperties being reset
3242
12-11-2014 02:20 PM
ChrisSmith10
I would like to programmatically set the HydrographicS52DisplayProperties to custom values and let the user change those values through a dialog. The problem that I am running into is that loading the first S-57 layer overwrites my changes.
This seems like a bug to me.
var HydroS52DisplayProperties = HydrographicS52DisplayProperties.Default;
HydroS52DisplayProperties.TextGroupProperties.BerthNumber = false;
HydroS52DisplayProperties.TextGroupProperties.GeographicNames = false;
// load a hydro layer into the map
var layer = new HydrographicS57Layer();
layer.DisplayName = "Sacrificial Layer";
EsriMap.Layers.Add(layer);
// after the layer is loaded the HydrographicS52DisplayProperties
// will be reset to the defaults. BerthNumber and GeographicNames
// from above will be true
I'm using Runtime .NET SDK version 10.2.4.748
Tags (1)
AnttiKajanus1
At the moment settings get reset but you can change values after you wait layers loaded.
// wait until all layers are loaded
await MyMapView.LayersLoadedAsync();
HydrographicS52DisplayProperties.Default.ViewGroupProperties.Soundings = false; // changes
