Populate attribute table from other layers ArcGIS Online
3956
12-11-2014 11:48 AM
TomKearns
I am publishing a web service with a point featureclass that has many attributes that I would like auto-populated from other layers when a new point is dropped.
Work flow:  User creates a new point, attributes such as lat/lon, slope, aspect... are filled in.
I know I can write a script to do this with selections or intersects after all the points are in, but I would like for it to show during the editing session.  Is this possible?
Thanks.
TimWitt2
I don't think this is possible within ArcGIS Online. However in ArcGIS Desktop you could use the attribute assistant to do this for you, which is included here.
TomKearns
Thanks, I saw this referred to when doing a background investigation but was under the impression it was only in 10.2 and we are still on 10.1. The doc you sent says it is available, I will have to look into it further.
TimWitt2
Reynaldde_Castro
We use FME by Safe Software to run a process that will update values of another field based on values from another.
