Customising "Features" row text
4691
12-09-2014 06:55 AM
PeteCrosier
In AGOL I can configure the title that's shown on a web map pop-up for a feature and this flows through to the feature's attributes page in Collector. Is there a way to get this title to be shown in the "Features" list in Collector (where you see a list of everything selected)?
Currently it looks like Collector has picked two attributes at random for a feature layer and is using them in the Features list, but unfortunately the ones it has picked for me don't have much use to the user. I don't want the user to have to go in to each feature to see if it's the one they want. Thanks!
(Quick edit - the search results list is smarter than the Features list as it shows the attribute that you've searched on, which makes sense.)
JuliaMason
In case you are still struggling with this, found the answer here: Re: ArcGIS Collector Selection popup preview
You need to modify the Display Expression on the Display tab of the layer properties in desktop.
JuliaMason
PeteCrosier
Thanks - bit annoying that it's something that you can mess up early in the process and not be able to change later, but good to know!
