How to find NED 30 needed for a watershed delineation?
949
12-04-2014 01:56 PM
FaridAria
I am trying to delineate a watershed in Washington DC and I need NED 30 for it. How can I get it. I know it can be find in National Map Viewer but I go to download section there are about 200 file names and I can't figure out which one to download.
ChrisDonohue__GISP
I'm not an expert on DEM's and their downloads, but here's some ideas based on my likewise flailing around on my infrequent downloads of them:
An idea - there are several options in Download Data section of the National Map Viewer.  One is "Click here to draw and download based on a bounding box."  This could help limit your selection.
Also, I believe the 30 meter DEM's match the same extents of USGS 24K Topo Quads (though I could be off on this).  This may offer another way to determine which ones you need - there is a reference layer that can be displayed for the 24k Quads.
Then the crux issue - once you go to the Download function, it returns a long list of different files, making it difficult to figure out which one needs.  I believe for 30meter DEM's the files you want to download are just the ones listed as "1 arc-second" under the Resolution column. However, I'm not 100% sure on that - maybe someone who is more knowledgeable can chime in on that?
Hope this helps,
Chris Donohue, GISP
ChrisDonohue__GISP
Hope this helps,
Chris Donohue, GISP
