How to change selection color for a feature layer
2608
12-01-2014 04:46 AM
AndreaV
Hi, is there any way to change selection color for a feature layer in Python without setting this using a lyr?
Thank's in advance.
Andrea
Tags (1)
curtvprice
You could do a workaround by setting the selection symbol, saving to a .lyr file, and loading the layer and setting the source using arcpy.mapping. This is really the only way to mess with things not exposed as arcpy.mapping object methods.
XanderBakker
Esri Esteemed Contributor
I don't see the selection symbol being exposed in the arcpy.mapping.Layer object. so I guess the answer is No.
curtvprice
AndreaV
Ok, so I have no chance to set directly. Thank you for the workaround.
