Keep Python as the scripting language in Field Calculator
3934
8
12-01-2014 11:59 AM
JoeBorgione
I'm finally dragging myself kicking and screaming into Python after using VB for a number of years to calculate field values.  It's really frustrating to have a script run fine on one or two selected records, only to have it immediately bomb out on the entire table of records: especially when the only problem is the calculator has reverted back to VB automagically.
Is there a way to keep Python as the scripting language default or, how do I keep it from reverting back to VB?    (Using version 10.0 desktop)
Zeke
Honored Contributor
Not as far as I know. It should retain python within a session, but not as a general setting. It would seem like a  no-brainer since ESRI's embraced python and VBScript is no longer supported, but there you have it. Maybe at 10.3 or 11, whenever they come out.
JoeBorgione
That's what I figured, but for whatever reason, the script stays intact, but the radio button goes back to VB: it craps out in a hurry...
Zeke
Honored Contributor
Well, I'm on 10.2.2, maybe that particular bug has been taken care of, if I understand correctly. I've been caught by it myself before.
curtvprice
The interactive right click field / calculate  method is the "old" way to do it and the interface is used to call the Calculate Field tool - after that first run you can recall it from the Results window where it will be "stuck" for you with the parameters you want.
JoeBorgione
Seems like a number of extra clicks just to get back to the old style right click on the field. But if that works for you, it's cool with me...
KevinBell
https://c.na9.visual.force.com/apex/ideaView?id=08730000000brslAAA
I posted this to the esri idea submission site in 2011, so go vote for it!
Zeke
Honored Contributor
I don't think that's the link you want. Goes to SalesForce.
AlexanderNohe1
Honored Contributor
Hi Kevin,
I believe this is the link that you want:
ArcGIS Idea - Field Calculator default to Python
