Accessing a SQL Server Table View
2630
12-01-2014 08:21 AM
by Anonymous User
Not applicable
I have a table view in SQL Server which was created with Management Studio. This View does not appear in ArcCatalog/ArcMap. Is it possible to view this table view somehow and ultimately publish it via ArcGIS Server? I understand there is a Create View tool however my question is it possible to view the native table view created in Management Studio?
Thanks!
RGibson
JakeSkinner
Esri Esteemed Contributor
Hi Russell,
Yes, it's possible to access the view you created in Management Studio and publish it to ArcGIS for Server.  Are you connected to the database as the same user that created the view in SQL Server Management Studio?
Also what version are you using?  Ex:
ArcSDE 10.2.2
SQL Server 2008
by Anonymous User
Not applicable
Hi, Jake. Thanks for the fast answer...
Yes, connected as the same user and 10.2
rg
JakeSkinner
Version of SQL Server?  Also, can you provide the SQL you used to create the view?
by Anonymous User
Not applicable
2008 R2
In Management Studio:
SELECT     OBJECTID, NewSegID, OldSegID
FROM         dbOwnerName.myTableName
