Halt/wait VB.net processing until Python script is complete.
3303
11-26-2014 09:57 AM
DaleShearer
Thanks for looking at my issue.  I am calling a Python script with arguments from my VB.Net application.  What I want to do is have the VB.net application wait on the Python script to complete before it continues processing.
I am currently starting the Python script like this:
Dim A1 As String = "ExcelFile.xlsx"
Dim A2 As String = "DbfFile.dbf"
Shell("C:\Python27\arcGIS10.2\python.exe C:\PythonScripts\ExceltoDBF.py " + A1 + " " + A2)
It works fine.
I am trying the following code, from what I have found the structure of the exe and arguments are correct(maybe-maybe not?).  What occurs is the executable does work as the black window opens then immediately closes.
Dim procStartInfo As System.Diagnostics.ProcessStartInfo = New System.Diagnostics.ProcessStartInfo("C:\Python27\arcGIS10.2\python.exe", "C:\PythonScripts\ExceltoDBF.py " + A1 + " " + A2)
procStartInfo.RedirectStandardOutput = True
procStartInfo.UseShellExecute = True
procStartInfo.CreateNoWindow = False
Dim proc As New System.Diagnostics.Process()
proc.StartInfo = ProcStartInfo
proc.Start()
proc.WaitForExit()
Any ideas, do I have the code structure right?
Thanks for your time, Dale
DaleShearer
Well that was not too hard to fix, in a couple of lines of code that I was alternating between, in one line I had a space between "Python" and "Scripts": C:\Python Scripts\ExceltoDBF.py
Once I removed the space it worked fine:  C:\PythonScripts\ExceltoDBF.py
curtvprice
Why aren't you using the Wait property of the Shell function? Seems like that would be less trouble...
Shell Function
