Custom widget and popup problem
776
11-26-2014 03:55 PM
JeremieCornet1
Hi all,
In a custom widget, i add to the map a graphics layer which displayed differents query results.
I added a handle to the event click of this layer which display the map.infoWindow with a specific content.
With this configuration, the popup displa yon click and close in no time.
If i add a setTimeOut (500 ms) to open the infowindow, it works.
I assume that on graphic click :
- event click on graphics layer
- event click on map (handle by WAB to display the portal map popup ?)
   -> this handle may close the popup because no "standard" (e.g. define in the portal map) feature under ?
Is this a proper way (than settimeout) to deal with this ?
I don't need WAB popup so is there a way to disconnect WAB map click handling (with reference to this handle, i could use dojo.disconnect) ?
Jérémie - MAGIS NC
GIS enthousiast, python & javascript lover
