Replicating Data with Attachments
4377
11-26-2014 02:39 PM
mpboyle
Honored Contributor
Does anyone have a good workflow for replicating data to another geodatabase that contains attachments?  I realize using a distributed geodatabase would work, but that will only work for versioned enterprise data...and we have some enterprise data that is non-versioned.
I have only just started looking for solutions and the only one I've found that works so far is using the Copy tool which when you copy the parent feature class, the attachments are copied as well.  The downside I've found with this is that data doesn't seem to want to copy into a dataset that doesn't have the same spatial reference...so copying to the root of the geodatabase works, but not to a dataset with a different spatial reference.
Thanks for any ideas!
PeterSchneider
Matt,
The way I am reading your question is -
DB1 replicates to DB2 (has attachments) is this correct?  In essence, loading data from a feature class without attachments into one that does?
