datatypes
4262
6
11-25-2014 11:31 AM
deleted-user-Pi5x1UjkS2PY
I am storing my dypes in a string but it does not seem to like it.  Anyway that I can do something like this.  I'm sure their is a simple fix.  Code works if I hard code instead of the string but I am trying to make this a function so that I can reuse this code.
    datarray = []
    #for row in cursor:
    for row in cursor.fetchall():
    dtype = np.dtype(get_dtype)
    #dtype = np.dtype([('YEAR', '<f8'), ('REGIONID', '<f8'), ('DISTRICTID', '<f8'), ('REGIONNAME', '|S255'), ('DISTRICTNAME', '|S255'), ('DIVLOC', '|S255'), ('STORENAME', '|S255'), ('CLUSTER', '|S255'), ('SUBID', '|S255'), ('SUBNAME', '|S255'), ('SEQUENCE', '<f8'), ('S_AREA', '<f8'), ('FS_AREA', '<f8'), ('ST_AREA', '<f8'), ('FR_AREA', '<f8'), ('SO_AREA', '<f8'), ('SL_AREA', '<f8'), ('TOTALSALES', '<f8'), ('OWNEDSALES', '<f8'), ('LEASEDSALES', '<f8'), ('GM', '<f8'), ('PROD', '<f8'), ('GMPROD', '<f8'), ('LATITUDE', '<f8'), ('LONGITUDE', '<f8'), ('RANKSALESSUB', '<f8'), ('RANKPRODSUB', '<f8'), ('RANKSALESSUBD', '<f8'), ('RANKPRODSUBD', '<f8'), ('RANKSALESSUBR', '<f8'), ('RANKPRODSUBR', '<f8'), ('RANKSALESSUBS', '<f8'), ('RANKPRODSUBS', '<f8'), ('RANKSALESSUBC', '<f8'), ('RANKPRODSUBC', '<f8')])
Getting this error:
  File "T:/Current/GISWeb/Python Script/PublishBaseMapsMXDToServer.py", line 400, in defAddSQLTable_CreateShapefile
  File "C:\Python27\ArcGIS10.2\lib\site-packages\numpy\core\_internal.py", line 234, in _commastring
    newitem = (dtype, eval(repeats))
  File "<string>", line 1
SyntaxError: unexpected EOF while parsing
XanderBakker
Esri Esteemed Contributor
Hi Michael,
I haven't looked at the entire function, but I did notice 2 things:
  • The statement get_dtype = .... has an additional ")" just before the end. Remove this and the string is ok
  • However, you can't supply the string to the np.dtype function, but you can use an eval statement to solve this (this way the string is converted to the required list)
get_dtype="[('YEAR', '<f8'), ('REGIONID', '<f8'), ('DISTRICTID', '<f8'), ('REGIONNAME', '|S255'), ('DISTRICTNAME', '|S255'), ('DIVLOC', '|S255'), ('STORENAME', '|S255'), ('CLUSTER', '|S255'), ('SUBID', '|S255'), ('SUBNAME', '|S255'), ('SEQUENCE', '<f8'), ('S_AREA', '<f8'), ('FS_AREA', '<f8'), ('ST_AREA', '<f8'), ('FR_AREA', '<f8'), ('SO_AREA', '<f8'), ('SL_AREA', '<f8'), ('TOTALSALES', '<f8'), ('OWNEDSALES', '<f8'), ('LEASEDSALES', '<f8'), ('GM', '<f8'), ('PROD', '<f8'), ('GMPROD', '<f8'), ('LATITUDE', '<f8'), ('LONGITUDE', '<f8'), ('RANKSALESSUB', '<f8'), ('RANKPRODSUB', '<f8'), ('RANKSALESSUBD', '<f8'), ('RANKPRODSUBD', '<f8'), ('RANKSALESSUBR', '<f8'), ('RANKPRODSUBR', '<f8'), ('RANKSALESSUBS', '<f8'), ('RANKPRODSUBS', '<f8'), ('RANKSALESSUBC', '<f8'), ('RANKPRODSUBC', '<f8')]"
dtype = np.dtype(eval(get_dtype))
Kind regards, Xander
XanderBakker
What would be the string that holds the dtypes?
Maybe these links are helpful:
The other thing is, that it might not be a good idea to use fetchall. See this post:
Arcpy - execute sql query in oracle error
It is a bit difficult to see what is going on, when you post a small part of the code.
This is the whole function
I am hoping to be able to create the dtype on the file using all of the fields in a table to create a shapefile.  We use a view in SQL to limit the fields we want so I just want all of them.  Since we update these all of the time and we have quite a few I am trying to automate this process.
so this works:
however this does not:
get_dtype="[('YEAR', '<f8'), ('REGIONID', '<f8'), ('DISTRICTID', '<f8'), ('REGIONNAME', '|S255'), ('DISTRICTNAME', '|S255'), ('DIVLOC', '|S255'), ('STORENAME', '|S255'), ('CLUSTER', '|S255'), ('SUBID', '|S255'), ('SUBNAME', '|S255'), ('SEQUENCE', '<f8'), ('S_AREA', '<f8'), ('FS_AREA', '<f8'), ('ST_AREA', '<f8'), ('FR_AREA', '<f8'), ('SO_AREA', '<f8'), ('SL_AREA', '<f8'), ('TOTALSALES', '<f8'), ('OWNEDSALES', '<f8'), ('LEASEDSALES', '<f8'), ('GM', '<f8'), ('PROD', '<f8'), ('GMPROD', '<f8'), ('LATITUDE', '<f8'), ('LONGITUDE', '<f8'), ('RANKSALESSUB', '<f8'), ('RANKPRODSUB', '<f8'), ('RANKSALESSUBD', '<f8'), ('RANKPRODSUBD', '<f8'), ('RANKSALESSUBR', '<f8'), ('RANKPRODSUBR', '<f8'), ('RANKSALESSUBS', '<f8'), ('RANKPRODSUBS', '<f8'), ('RANKSALESSUBC', '<f8'), ('RANKPRODSUBC', '<f8')])"
# All of the function.
def defAddSQLTable_CreateShapefile(strTableName, strFilePath, strShapeFileName):
##Trying to make one function for publishing files to server.
defSQLTableGetFieldNamesForSQLStatement
    print strTableName
    cnxn = pyodbc.connect("DSN=AR")
    cursor = cnxn.cursor()
    get_select_statement = "Select "
    get_dtype = "["
    #"Returns all rows from a cursor as a dict"
    for row in cursor.columns(table=strTableName):
        if row.data_type == 4 or row.data_type == 6 or row.data_type == 2:
            get_select_statement = get_select_statement + "ISNULL(" + row.column_name + ", 0), "
        else:
            get_select_statement = get_select_statement + row.column_name + ", "
            get_dtype = get_dtype + "('" + row.column_name + "', '<f8'), "
        else:
            get_dtype = get_dtype + "('" + row.column_name + "', '|S255'), "
    get_select_statement = get_select_statement[0:-2]
    get_dtype = get_dtype[0:-2] +"]"
    print get_select_statement
    #print get_dtype
    defDeleteFileIfItExist(strFilePath, strShapeFileName)
    strfields = get_select_statement
    strfrom = " From GISWEB."+strTableName
    cursor.execute(strfields+strfrom)
    datarray = []
    #for row in cursor:
        datarray.append(tuple(row))
    print get_dtype
    WKID = 4326 # WGS-1984
    sr = arcpy.SpatialReference()
    sr.factoryCode = WKID
    sr.create()
    env.outputCoordinateSystem = sr
    npyarr = np.array(datarray, dtype)
    out_fc = strFilePath + strShapeFileName
    if arcpy.Exists(out_fc):
        #memoryFeature = "in_memory" + "\\" + "myMemoryFeature"
        #arcpy.CopyFeatures_management(out_fc, memoryFeature)
        arcpy.Delete_management(out_fc)
        arcpy.Delete_management("in_memory")
    env.overwriteOutput = 1
    arcpy.da.NumPyArrayToFeatureClass(npyarr, out_fc, ['LONGITUDE','LATITUDE'], sr)
    cnxn.close
    cursor.close
XanderBakker
Hi Michael,
XanderBakker
Since the line is long and the width limited here is what I was referring to (check the how the statement ends):
get_dtype="[('YEAR', '<f8'), ... , ('RANKPRODSUBC', '<f8')]"
That was exactly what I was missing.
For anyone in the future trying to do this this was what helped me.
This will save me a lot of work in the future.  Thanks very much.
curtvprice
Michael, please consider moving this discussion to the Python‌ space using the "move" link you see at right when you're look at this this thread.
