Field names and field count
3691
11-22-2014 09:04 PM
ababreddy
Hii, i am trying to display Field names and field count. here is my code but i am not getting result. Please help me
            IMxDocument pmx = m_application.Document as IMxDocument;
            IMap pmap = pmx.FocusMap;
            ILayer layer = pmap.get_Layer(0);
            IFeatureLayer pflayer = (IFeatureLayer)layer;
            IFeatureClass fc = pflayer.FeatureClass;
            IFields fields = fc.Fields;
            int fieldCount = fields.FieldCount;
            int endFieldIndex = fieldCount - 1;
            int fieldIndex = 0;
            while (fieldIndex <= endFieldIndex)
                IField field = fields.get_Field(fieldIndex);
                Console.WriteLine("The field at field index {0} is named (1)", fieldIndex, field.Name);
                //MessageBox.Show("The field at field index {0} is named (1)", fieldIndex.ToString(), field.Name);
                fieldIndex++;
FreddieGibson
Honored Contributor
Your logic looks correct to me. If you step through your code could you verify that fc.Fields is returning values?
I wrote up a quick console application to test this and everything works fine for me. I've pasted my logic below if you want to give it a shot.
using ESRI.ArcGIS.Carto;
using ESRI.ArcGIS.esriSystem;
using System;
using System.Windows.Forms;
namespace ListFields
    class Program
        [STAThread]
        static void Main(string[] args)
            ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.Desktop);
            IAoInitialize aoInit = new AoInitializeClass();
            aoInit.Initialize(esriLicenseProductCode.esriLicenseProductCodeAdvanced);
            var mxdPath = BrowseFolderForFile("Please select a *.mxd file", "Map Document (*.mxd)|*.mxd");
            if (string.IsNullOrEmpty(mxdPath))
                throw new ArgumentException("Invalid MXD Path");
            var mxd = new MapDocumentClass();
            mxd.Open(mxdPath, string.Empty);
            var uid = new UIDClass { Value = "{40A9E885-5533-11D0-98BE-00805F7CED21}" };
            for (int i = 0; i < mxd.MapCount; i++)
                var map = mxd.Map;
                var enumLayer = map.Layers[uid, true];
                enumLayer.Reset();
                ILayer layer;
                while ((layer = enumLayer.Next()) != null)
                    var featClass = (layer as IFeatureLayer).FeatureClass;
                    Console.WriteLine("Layer {0} has {1} fields.", layer.Name, featClass.Fields.FieldCount);
                    for (int j = 0; j < featClass.Fields.FieldCount; j++)
                        Console.WriteLine("...{0:00}. {1}", j, featClass.Fields.Field.Name);
            Console.Write("\nPress enter to exit...");
            Console.ReadLine();
        static string BrowseFolderForFile(string title, string extension)
            OpenFileDialog openFileDialog = new OpenFileDialog
                Filter = extension,
                Multiselect = false,
                ShowHelp = true,
                Title = title
            return openFileDialog.ShowDialog() == DialogResult.OK ? openFileDialog.FileName : null;
