Arcpy - execute sql query in oracle error
2836
7
11-19-2014 08:05 AM
Pierre-LucBoivin
I have to execute a sql query from an oracle table but the problem is that according to a new argument that is true, I have to make a connection to another table.
My original script that i've been using for 2 years works like a charm so I just add an if statement in the connection variable but when comes the time to populate my temp table I got this error :
I tried to put  rows = cursor.fetchall() in my if statement and it doesn't work either.
The line 75 refer to the line in red
if rdc == True:
    sql = "SELECT * FROM INTERVENTIONS_GEO_UNITES_RDC" + arg1
    cursor.execute(sql)
else:
    sql = "SELECT * FROM INTERVENTIONS_GEO_UNITES WHERE " + arg1
    cursor.execute(sql)
avec_rdc = (row for row in rows if rdc == True)
sans_rdc = (row for row in rows if rdc == False)
for row in avec_rdc:
        trow = iCur.newRow()
        trow.INCIDENT_N = row[0]
        trow.DATE_INTER = row[2]
        trow.ADRESSE_IN = row[3]
        trow.TYPE_INT = row[4]
        trow.CAS_NO = row[5]
        trow.REGION = row[6]
        trow.CATEGORIE = row[7]
        trow.SITE_KEY = row[8]
        trow.ARRONDISSE = row[9]
        trow.LISTE_UNIT = row[11]
        trow.LONGITUDE = row[12]
        trow.LATITUDE = row[13]
for row in sans_rdc:
        trow.DATE_INTER = row[1]
        trow.ADRESSE_IN = row[2]
        trow.TYPE_INT = row[3]
        trow.CAS_NO = row[4]
        trow.REGION = row[5]
        trow.CATEGORIE = row[6]
        trow.SITE_KEY = row[7]
        trow.ARRONDISSE = row[8]
        trow.LISTE_UNIT = row[9]
        trow.LONGITUDE = row[10]
        trow.LATITUDE = row[11]
iCur.insertRow(trow)
thanks for your help
Tags (3)
JamesCrandall
MVP Frequent Contributor
Total guess here, but "rows" is empty.
What is the value of "arg1"?  If it's numeric, you may  need to convert it to string, as well as add an extra space after the SELECT statement:
sql = "SELECT * FROM INTERVENTIONS_GEO_UNITES_RDC " + str(arg1)
JamesCrandall
Probably of more importance.....
Get rid of the "SELECT *" !!!
I am of the mind that it's just silly to have this in any production environment.  I see you have the fields listed out for your cursor, it's probably even more important to have them listed in your SQL.
ChrisMathers
The syntax highlighting is having a dang fit so I did a pastbin of what I think would work. Paste #nnwkcPiRJshsKg0vgr0J at spacepaste
Its also not a good idea to use fetchall() generally. If you know you're getting a small result set its OK but because the entire result is being read into memory your can run into problems. Better to do something like what is below. Its wordier but it keeps your memory usage down.
while True:
     row = cursor.fetchone()
     if row == None:
          break
     if rdc:
          avec_rdc.append(row)
     else:
          sans_rdc.append(row)
JoshuaBixby
MVP Esteemed Contributor
I agree with James Crandall‌ about SELECT * .
Are you using pyodbc?  If so, fetchall() returns an empty list, even if no rows are returned, so I don't get why rows wouldn't be defined.  If a successful query, even one with no results, returns a list that could instantiate rows; maybe the queries are generating an error and fetchall is returning nothing, so rows doesn't exist.
JamesCrandall
OP is probably using cx_Oracle
Pierre-LucBoivin
Hi thank for all your answers !!
It was kind of my first python script so i'm open to fix it to optimize my code.
James is right i'm using cx_Oracle for my connection.
Here what my sql query look likes
SELECT * FROM INTERVENTIONS_GEO_UNITES WHERE TYPE_INT <> '1ERREP' and DATE_INTER BETWEEN TO_DATE('01/01/2011 00:00:00', 'MM/DD/YYYY HH24:MI:SS')  AND TO_DATE('12/31/2011 23:59:59', 'MM/DD/YYYY HH24:MI:SS') and ARRONDISSEMENT_VILLE in ('Côte-des-Neiges--Notre-Dame-de-Grâce','Plateau-Mont-Royal','Outremont')
or if it with rdc here my query pratically the same except they add a suffix RDC at the view name.
SELECT * FROM INTERVENTIONS_GEO_UNITES_RDC WHERE TYPE_INT <> '1ERREP' and DATE_INTER BETWEEN TO_DATE('01/01/2011 00:00:00', 'MM/DD/YYYY HH24:MI:SS')  AND TO_DATE('12/31/2011 23:59:59', 'MM/DD/YYYY HH24:MI:SS') and ARRONDISSEMENT_VILLE in ('Côte-des-Neiges--Notre-Dame-de-Grâce','Plateau-Mont-Royal','Outremont')
What I don't understand is that i can execute the script without any problems when I don't have the condition True or False with this code
cursor.execute(sql)
I'll try the differents options that you guys gave me and come back for the feedback of my tests
Thanks you
JamesCrandall
The difference is that you fixed the sql:
sql = "SELECT * FROM INTERVENTIONS_GEO_UNITES_RDC " + arg1
Before you had it without any space between the sql string  and your arg1 value (there was no space between the RDC and the last quote):
