Simple Edit widget syntax question
2475
11-17-2014 11:50 AM
MegPeterson
Hi all -
I have one feature in my .mxd that I have successfully published as a feature and map service. The feature is registered in a versioned enterprise database.
For that life of me I can't seem to follow the example in configuring the main config.xml and edit.xml to view and edit the feature layer. I'm going bonkers. I keep getting error #1090 (a problem occurred while parsing the config.xml).
The tags in the operational layers look like:
<operationallayers>
   <layer label="Edit file" type="feature" visible="false" alpha="1" url="http......../FeatureServer/0"</layer>
   <layer label="View file" type="dynamic" visible="true" alpha="1" url="http..........MapServer"</layer>
And my Edit.xml calls the <layer name="Edit file"> from the <layersettings>.
And help? Gah! (And thanks!)
AnthonyGiles
Honored Contributor
Meg,
You are not closing your layer tag off correctly, try using this:
<layer label="Edit file" type="feature" visible="false" alpha="1" url="http......../FeatureServer/0" />
Regards
Anthony
AnthonyGiles
Honored Contributor
Meg,
Regards
Anthony
MegPeterson
Oh geez....thanks Anthony. You've saved my marbles.
